Engine Troubleshooting
Old Sep 21, 2010 | 07:22 PM
bkgregory's Avatar
Default Engine Troubleshooting
1999 Accord EX 4cyl.- 103K ....at speed of 50..60.70..can feel slight studder in engine as if it is missing. Replaced timing belt, plugs, wires, dist cap, rotor, verified timing, ohm tested coil, checked fuel pressure regulator, put fuel injector cleaner in 2 times....Any suggestions?
Old Sep 21, 2010 | 07:31 PM
Does the check engine light turn on or D4 light start flashing when driving? Also, what rpm range does it happen?
Old Sep 21, 2010 | 07:39 PM
And... was it doing this before you changed the timing belt?
Old Sep 21, 2010 | 09:08 PM
bkgregory's Avatar
cant say it was doing it before the timing belt was replaced. I verified timing to be sure i wasnt off by a tooth. no check engine light...seems to be noticeable around 2000-3000 steady RPMs only. very slight jump...
Old Sep 21, 2010 | 11:37 PM
The one thing I can think of is cleaning the EGR port.
The 98-02 4 cylinder requires removing the throttle body and upper intake manifold. It isn't too bad to remove.
See this thread with some info:
https://www.hondaaccordforum.com/for...ad.php?t=31084
Old Sep 22, 2010 | 07:08 AM
I was thinking of the balance-shaft belt being a bit off time. I assume you checked that too?
Old Sep 22, 2010 | 09:19 AM
bkgregory's Avatar
Thanks for the recommendations.
94Honda
Oct 30, 2009 02:14 PM
rplowden
Jan 22, 2008 03:17 PM
BeansBaxter
Dec 10, 2007 08:30 PM
jhowkins
Nov 1, 2007 01:07 AM
rcy
Apr 6, 2007 01:29 PM
