erratic idling between cold to warm
Hello i have a 1992 honda accord mt. It idles erratically after it warms up for a couple minutes but before it is completely warmed up. it jumps back and forth between 1200rpm to 1800rpm. Once it is totally warmed up and if i cut car off and then return to restart it then will idle normally.
You might be able to tighten the plunger inside the FITV; there's a thread about that in the DIY area. Then you can look at all the other things that can cause a surging idle, listed in a post by me about setting the "BASE idle".
That is, if the idle surges during warmup. If it idles high then smoothly decreases as it warms up, that's normal like holmesnmanny says.
thats not what it does. Before it gets warm it will idle erratically between 1200 to 1800. JUmping back and forth until u cut engine off after it is warm. Once u cut off engine once it is warmed up then it will idle correctly. Of course i know it is suppose to idle higher when it is cold.
M-train
07-11-2023 06:34 AM
