Error codes
Old Jan 10, 2017 | 11:42 AM
Alrye's Avatar
Default Error codes
Can I still drive my 2001 accord lx with error codes p0700 and p0740 showing?
Old Jan 10, 2017 | 02:19 PM
The Toecutter's Avatar
I can't find code 0700, but code 0740 is lock up control system (AT), and the D4 light would be off, but the MIL light should be on.
Old Jan 11, 2017 | 03:14 PM
I drove a 97 Acura TL (2.5L) for several years w/ P0740 (P0700 is general transmission fault and is associated w/ P0740).
P0740 is a hydraulic fault in the torque converter lockup circuit. It can be a bad solenoid valve (stuck closed) or trash in hydraulic circuit. The code is set when a mismatch between engine speed and drive train input shaft speed is detected by speed sensors (torque converter slip is occurring, ie no lockup).
In my case the fault would only be set when speed exceeded 55 mph. Yours could be different. You can observe this result by setting speed control on a slight grade (no downshift). As you go uphill, engine should lug at same rpm/speed if lockup is present, however w/ this code you'll see rpm rise by 150-250 rpm as you hold speed w/ cruise.
BigShelby
Dec 18, 2015 09:36 PM
voteforpedro
Oct 6, 2009 02:54 AM
jeffv
Oct 4, 2009 09:43 PM
pturnbul
May 3, 2007 02:30 PM
CasualObserver
Dec 14, 2006 02:06 AM
