Evap Control Canister
Old Nov 28, 2007 | 07:44 PM
violated
Default Evap Control Canister
Took a 50 mile trip and got off the interstate and noticed smoke coming from under the car, pulled over and looked for the problem. I believe it was a liquid draining out of the Purge Air Hose and spraying on the catalyctic converter. Check Engine Light never came on and it didn't store any codes and was wondering if this is something i should be worried about.
Old Nov 28, 2007 | 11:45 PM
Default RE: Evap Control Canister
Did you fill gasoline when you got off? Reason is, I wonder about overfilling the tank & somehow liquidgetting thru the vent line to the EVAP canister. If it were gasoline, you should have smelled it.
Or do you think it could have been the water drain from the ventilation air ducts?
Old Dec 1, 2007 | 10:05 AM
HondatechAV6's Avatar
ORIGINAL: JimBlake
x2
Dakotademon7
Dec 17, 2014 08:53 PM
1madracer
Mar 21, 2012 05:08 PM
jfidelh
Dec 1, 2011 01:39 PM
JimBlake
DIY Answers.
Aug 6, 2009 01:36 PM
bww
Sep 23, 2007 10:24 AM
