EVAP Purge Valves & STFT ?
Old Apr 12, 2012 | 03:15 AM
kiwibilt's Avatar
Smile EVAP Purge Valves & STFT ?
Aloha,
Anyone know the relationship between leaking EVAP purge valves & short term fuel trim. I have consistantly lean Long & short term trims (-6 to -7) & know if I pinch the purge vapor hose, the stft will return to normal parameters if the valve is leaking.
My question is...would a leaking purge valve cause the motor to run rich or lean ?.
Mahalo
Old Apr 12, 2012 | 05:51 AM
The ECU will sense the air leak (O2 sensor readings) and compensate by changing Long Term Fuel Trim (LTFT) which will be negative. If LTFT exceeds a lmiit, perhaps 35-40%), then Check Engine Light is set on. Probably obd1 code 43 for fuel supply is set.
Old Apr 13, 2012 | 04:49 PM
kiwibilt's Avatar
Thanks Tex,
Ended up being the hose between the Purge Valve & the manifold. Fuel trims fine now. I wanted to fix it before I replaced the cat.
Comnavman
Mar 18, 2014 09:42 AM
jfidelh
Feb 26, 2013 10:03 AM
jonmad99
Feb 16, 2011 06:42 PM
hondadude
DIY Answers.
Mar 2, 2010 09:21 AM
Ericsmiller88
Feb 20, 2007 02:25 PM
