evaporator and expansion valve, 2003 6mt coupe
Old Jun 19, 2012 | 10:38 AM
cldoole's Avatar
Line from compressor to condensor is discharge line. Line from evaporator to compressor is suction. Both lines have lengths of aluminum tubing.
If compressor is whining after the system leaked down due to tubing defect, then compressor idler bearing is worn out. Apparently you have bought a replacement compressor so bearing fault doesn't matter.
I would be tempted to leave evaporator and expansion valve alone, but if warranty requires this perhaps it's worth the extra effort. Unlikely to yield any benefits and could result in problems. Replace all orings and take your time.
Get a Honda shop manual!
Man! so I could have just replaced the bearing in the compressor the re-install it?
Yea, replacing the expansion valve does seem like it may create another problem.
GIXER7502006
Sep 3, 2012 01:03 PM
jroe_28
Apr 15, 2009 07:15 PM
dsettlemoir
Jul 7, 2008 07:05 PM
joeaksa
May 13, 2007 10:39 PM
ballistic
Aug 27, 2006 05:56 PM
