F22A6 Head bolts and questions
Old Aug 12, 2012 | 07:56 PM
Stonent's Avatar
Default F22A6 Head bolts and questions
Trying to pull the head on a 93 to see if the valves are bent because I'm not getting compression. I've broken or rounded several sockets. Today I got a different impact set with thinner walls and was able to get 2 of the final 3 bolts out. Now I'm stuck at the one in the bottom corner near the cam gear.
(FYI I did intend to do these all in the right order, and started that way but had to modify my strategy a bit when I got stuck)
I've been sitting on that one for several minutes with an impact with nothing and the breaker bar + 6 point 14mm is starting damage the bolt head or it will pop off.
I've tried WD40, liquid wrench, brake fluid, acetone... Pretty much everything I could think of but nothing. I don't have a torch so no luck there. (I live in an apartment and all my tools are in 2 red tool boxes.)
But another question. After cleaning out the "oil bath" under the cam,I saw what looks to be a hex shape in the head. Is that actually something that unscrews or just a design in the head?
twystedvinyl
Nov 11, 2011 06:34 PM
clutch811
May 17, 2010 02:02 PM
Rubberman2003
Nov 28, 2009 11:59 PM
amadeuscr
Mar 12, 2008 07:17 PM
1993accordSE
Apr 15, 2005 11:30 AM
