F23A1 engine
Old Dec 2, 2008 | 07:03 PM
F23A1
Default F23A1 engine
hello my name is jason and i have a 99 accord with the F23A1-2.3L vtec with 5spd man transmission. I am looking into slapping a turbo in soon but i need to know what the maximum stock horsepower thefuel sysytemcan handle. I have been looking into turbos and intercoolers and everything ill need with the turbo but i need to know how much i can put on it before i do my mods. So if someone can help me out with this that would be great! Thanks!
Old Dec 2, 2008 | 08:43 PM
Default RE: F23A1 engine
would want to upgrade the injectors, but stock fuel rail should be able to handle whatever you throw at it.
Old Dec 2, 2008 | 10:15 PM
falkore24's Avatar
x2 ...... injectors set your maximum power, a Walbro 255 never hurts, but everything else is good to about 800 HP. I think the OEM pump can handle about 200 WHP.
How much power are you looking to make?
Old Dec 3, 2008 | 06:44 AM
F23A1
well stock i have 150hp and im not looking to go crazy, im thinking after i put in intake,intercooler,turbo etc..i will only be getting and extra 50-60 hp more so do u think if i upgrade them fuel system everything else would be fine stock?
Old Dec 3, 2008 | 09:50 AM
finch13's Avatar
Didn't we have an 8 psi max on stock internals rule on here?
I agree with going with the bigger injectors, DSM 450cc injectors should do the trick. Otherwise, when you're in boost, the injectors are going to be running past their 100% duty cycle at like 4k rpms. You can probably hold off on purchasing them until you go to tune it.
Your stock fuel pump should be able to supply the bigger injectors, but if you plan on boosting past 8psi you'll probably need the RC 550cc injectors along with a Walbro 255 pump.
Old Dec 3, 2008 | 10:02 AM
falkore24's Avatar
Note that I said 200 wheel horsepower. Your 150 is more like 128 at the wheels.
And as Finch noted, 8psi is the limit on stock internals ..... 7 is fairly safe.
Old Dec 3, 2008 | 03:29 PM
F23A1
Hey thanks alot guys, i will be looking for some parts after christmas and if i have any questions ill come back to u guys...thanks again!!
Old Dec 5, 2008 | 08:33 AM
brintonwhalen's Avatar
ask for some forged connecting rods/ and some forged dished pistons for lower compression for christmas. long stroke and high compression with the f23 .
and if you get anything at all GET A GOOD TUNE!!! -
Old Dec 5, 2008 | 10:31 AM
jcocker03's Avatar
i thought turbos didn't play nice with Vtec?
Old Dec 5, 2008 | 10:57 AM
finch13's Avatar
It's just more difficult to tune them without a VTEC controller since VTEC engages at different points and can really screw with the tune.
cg31998
Dec 15, 2010 10:29 AM
kid the killa
May 12, 2010 11:20 PM
streetlimitz89
Apr 23, 2009 03:29 PM
Accord12404
Feb 23, 2009 12:23 AM
j_man_honda
Aug 9, 2007 07:31 PM
