Failed Emissions Need Help
Old Feb 5, 2009 | 11:46 AM
ali7up
Default Failed Emissions Need Help
I failed my emissions on a 95 accord lx, the reason was NOx was too high
25/25 NOx Allowed 945 Mines 1323
50/15 NOx Allowed 1045 Mines 1307
i was told the cat is bad to i replaced the cat with a walker cat, cleaned the egr ports, seafoam the crankcase, gas tank, oil, did an oil change drove 300 miles and went to retest and got this:
25/25 NOx Allowed 945 test 1470
50/15 NOx Allowed 1045 test 1535
it failed again with worse number? what can be wrong? thanks
Old Feb 5, 2009 | 12:02 PM
Problem is common w/ Accords and is usually caused by blocked EGR ports and passages. There is a DIY link to repair procedures to clean the EGR system.
Old Feb 5, 2009 | 01:12 PM
ali7up
i cleaned the egr system just like the dyi said
Old Feb 6, 2009 | 07:48 AM
obriener2054's Avatar
check your lambda sensors and cat
Old Feb 6, 2009 | 09:09 AM
This problem is usually caused by lack of EGR flow. I would check EGR valve (is vacuum available to open the valve); EGR-EGR manifold passage clean/open; EGR manifold ports open; and underlying ports from EGR manifold into intake manifold are open.
Old Feb 6, 2009 | 11:26 AM
ali7up
could it be the o2 sensor? when i get drive the car in the morning it shows the check engine light for code 9 CYG Sensor but after a while the light goes away
corlude
Nov 14, 2009 04:50 AM
sugargenius
Jul 31, 2008 07:31 AM
Jiinx
Jun 15, 2008 03:28 PM
chandlers dad
Sep 30, 2007 01:32 PM
camusmuse
Dec 9, 2006 08:29 AM
