fan keeps working after car shut off
Old Jun 20, 2007 | 11:39 AM
bboyalex's Avatar
Default fan keeps working after car shut off
Is it normal? Fan keeps working for a couple minutes after the car is turned off.
Old Jun 20, 2007 | 12:05 PM
Default RE: fan keeps working after car shut off
Some years it's normal, other years it's not. Honda has had 3 or 4 different control logic schemes for the radiator fans over the years.
Up to about '97 it's normal for it to run for a bit, IF the engine is sufficiently hot. It won't always run, especially in winter or if you don't drive far enough to get it hot.
Beginning in '98 it's not normal to run after.
Beginning in '03 I'm not sure yet...
Old Jun 20, 2007 | 12:57 PM
bboyalex's Avatar
Its a 97, and no it doesnt do that all the time, only when its fairly hot outside
Old Jun 20, 2007 | 11:33 PM
Sounds normal to me. It shouldn'trun long enough to run down the battery.
Old Jun 21, 2007 | 09:46 AM
wietgr's Avatar
I have a 94 that does the same thing. Im pretty sure its normal cosidering the fact that it only does it after a long drive...
Old Jun 21, 2007 | 03:44 PM
sir_nasty's Avatar
You are correct. If the car is hot enough it will continue to run even after you shut the car off....
lordgoose
Jun 22, 2011 10:21 PM
driscollmv
Feb 13, 2010 10:18 PM
thedaveman89
Jan 10, 2009 03:06 AM
mw011i
Oct 10, 2008 11:12 AM
cardiovoid
May 4, 2007 09:39 PM
