!!! FIXED !! WEIRD ELECTRICAL ISSUE HELP !! FIXED !!
Old May 23, 2007 | 09:12 PM
mig25's Avatar
Default !!! FIXED !! WEIRD ELECTRICAL ISSUE HELP !! FIXED !!
I recently replaced the radiator timer under the dashboard,
I removed an aluminum box to have it out of the way, replaced the timer. Everything is good, Except, that now I have no Gauge cluster lights and no tail lights.
I was reading the manual and found no clue.
Checked all fuses, they are all good.
[&o]Can someone please heeeeeeeelp ![&o]
Old May 24, 2007 | 12:31 PM
Rhoderman's Avatar
Default RE: WEIRD ELECTRICAL ISSUE HELP !!
You probably blew the tail light fuse. The tail light and instrument panel lights are on the same fuse for a reason ---> so you know when you don't have tail lights. Unfortunately, most people don't know this, and continue to drive without either!
Check your fuses, both under the dash and under the hood.
Be sure to post back what fixes it...
HTH,
Jim
Old May 24, 2007 | 12:34 PM
mig25's Avatar
That was my initial thought , but all fuses look good.
I couldn't find a bad one anywhere.
Checke the Manual for fuse location, all that I could find were good ...
Old May 24, 2007 | 03:50 PM
mig25's Avatar
I Fixed it !
Under the hood fuse box
For some reason I had moved the fuse from its original place. I moved it from #33 to #34
Put it back to #33
Fixed it ! see fuse locations below :
Metrex1992
Mar 9, 2025 10:33 AM
frazierja
Sep 17, 2012 07:49 AM
acrawl1
Jul 9, 2010 08:25 AM
calenatar
Mar 10, 2006 03:23 PM
