Fixing rust on top of my wheels! How much do I sand?
Old Jul 9, 2011 | 07:50 PM
Legend's Avatar
Default Fixing rust on top of my wheels! How much do I sand?
I noticed just today that the upper portion of my driver side back wheel has got rust. I took a sand paper and started cleaning it hoping to remove the rust and apply primer-paint on it but as I started sanding it, it got worse - something started coming off! I am not sure if this was the metal or the paint so I sprayed it with some primer and applied some spray paint. I should have taken the picture before spraying it but I panicked!
I was checking online to see how to fix this Rust Stop Paint. It says I need to sand the rust off but when do I know how to stop sanding? When I kept sanding, I started seeing the inside (as if it was being eaten alive!) and am not sure if I just buy that product and apply it or I continue sanding. Any suggestions please?
Old Jul 9, 2011 | 11:28 PM
Looks like that might be the clear coat coming off...
Old Jul 10, 2011 | 12:13 AM
Legend's Avatar
Hmm... you think so? I thought the metal was just falling down in pieces when I saw it. The more I was sanding it, the more it kept falling down so I stopped after a while thinking that I would destroy it completely. So do you advice me to take it out completely before applying the rust paint? Also, I saw something called Bondo putty. Do you have any suggestions related to these? Thank you.
Old Jul 10, 2011 | 12:22 AM
That wont work on alloy wheels..if your wheel is crumbling that bad then I would suggest a new or used wheel replacement...
Old Jul 10, 2011 | 12:24 AM
Legend's Avatar
Oh no. My wheels are perfectly fine. It is the bender above the rear passenger wheel.
MessAround
Jan 13, 2014 06:24 PM
Sadus
Sep 6, 2011 11:29 PM
NICK63
Nov 2, 2009 11:57 AM
faosh
Sep 15, 2008 03:46 PM
ourhonda
Dec 11, 2006 02:55 PM
