Flashing green shifter light
Old Mar 13, 2010 | 12:39 AM
jamess's Avatar
Default Flashing green shifter light
This problem started after I had the transmission replaced.2004 Accord 2.4 engine Automatic trans. The shift display on the dash green light starts to flash on the highway after you go above 55 MPH .
Seems as if there is another pattern that that I have discovered. If you go for approx 10 miles at 50 MPH then accelerate , the light doesn't Flash .Somebody says its a slipping overdrive clutch But it seems more electrical as the light wont flash when you give it the initial 10 miles at 50 MPH. thanks J. Small Vancouver B.C.
Old Mar 13, 2010 | 07:39 PM
If it like the older accords, the computer is detecting something wrong with the transmission.
There should be some information in the owner's manual about that light if it is flashing.
Old Mar 13, 2010 | 08:52 PM
That's just like a check-engine lamp for the auto-tranny. In 2004 I think there's no longer any SCS connector that you can jumper with a paperclip. Gotta go to some car-parts chain store, have them plug in a scanner & read the error code.
Down here in USA it's AutoZone or AdvanceAutoParts. Maybe Canadian Tire does that?
nigel
Oct 26, 2012 06:29 PM
uraceulose
Jul 16, 2010 01:09 AM
J88p
Dec 6, 2009 03:27 PM
dondrup
May 21, 2007 01:16 AM
