Flashing warning lights
Old Sep 16, 2013 | 06:07 PM
anyt777's Avatar
Default Flashing warning lights
I just replaced the alternator on my 2002 accord with an aftermarket alternator manufactured by Champion. Bought at CTC) Now when driving the following warning lights come on all at the same time ebrake, charge indicator and all doors, trunk and brake lamp out. They stay on a few seconds, then off for a minute or so then the cycle repeats. Happens only when driving, not idling. Should I have stuck with honda parts?
Old Sep 17, 2013 | 07:16 AM
Got a multi-meter? Measure the voltage at the battery terminals.
1. with everything turned off, after parked overnight.
2. engine idling, everything else turned off.
3. engine idling, everything turned ON (headlights, blower, stereo, window defogger, etc).
Old Sep 17, 2013 | 07:32 PM
anyt777's Avatar
Thanks. I will try this in the morning. I spoke to a tech rep at honda dealership and they advised that aftermarket alternators are not advised. The flashing lights are an indication that the alternator is faulty. I have an oem on order.
Old Sep 17, 2013 | 08:01 PM
Quack11's Avatar
This often happens when there is no or low charging from the alternator. Make sure its the right amp for your vehicle and double check the connectors.
Old Sep 17, 2013 | 08:53 PM
Did you turn in your original alternator for the core charge? Sometimes it's only the voltage regulator that's bad. That's the reason for testing stuff.
Old Sep 17, 2013 | 09:59 PM
anyt777's Avatar
I checked the output at the battery, engine running and got 14.5 volts.
Old Sep 17, 2013 | 10:03 PM
anyt777's Avatar
Turned in. This was a new alternator, not a rebuilt. Didn't think new would be bad.
Greenbamboo
Feb 4, 2013 10:03 PM
OhThreeVeeSix
Sep 25, 2009 02:12 PM
poolman
Aug 17, 2009 01:12 PM
pejaypreston
Mar 16, 2008 03:34 AM
matta2002
Feb 7, 2008 09:57 AM
