Floor vibration after fiiting new wheels.
Old Jun 8, 2011 | 03:37 AM
jgw's Avatar
jgw
Default Floor vibration after fiiting new wheels.
Hello
I have just fitted alloys to my 96 Accord (they were given to me, I wouldn't buy alloys for a 15 year old car).
Now when I turn left I get a vibration through the floor, nothing major but noticeable.
What is likely to be causing this? The offset appears to be fine (about a 6-7mm clearance between caliper and alloy).
The vibration is accompanied by a small noise which I can only descibe as being similar to the noise the brakes make when a pad is stuck, not that loud but sort of a friction noise.
The alloys are a standard Honda Alloy not a cheap aftermarket one.
The plan when I get time is to swap the front wheel over and see if the noise switched too, though I don't have time yet and just wanted some suggestions.
Thank you
Old Jun 8, 2011 | 01:13 PM
Swapping the tires to see if the noise moves is a good place to start, because you will eliminate or verify the tires.
Bilster
Nov 19, 2011 09:17 AM
koolaid_kid
Oct 12, 2009 08:08 AM
Hondapt
Sep 19, 2007 11:30 AM
inthedump
Jun 4, 2007 06:41 PM
BlueByYou
Oct 7, 2006 11:54 AM
