Flushing engine oil after blown head gasket
Old Apr 19, 2009 | 11:52 AM
freezerman's Avatar
Default Flushing engine oil after blown head gasket
I had the chocolate milk for engine oil after a blown head gasket. When I drained it I had 4.5 quarts come out. Half a quart must have been coolant. I scrubbed the valve cover clean and shiny with carb cleaner and the head was professionally cleaned. I'm worried about the rest of the engine still having sludge in it. Will it be enough to refill with fresh oil,run to operating temp. Drain oil and refill with fresh oil. I was thinking of then changing the oil again in a couple of weeks.
Old Apr 19, 2009 | 06:39 PM
draser's Avatar
The water and glycol from the antifreeze will get captured in the oil filter. Refill with fresh and use a new filter, run to temp then change oil and filter. Just like you said with a filter (2) twist.
Old Apr 27, 2009 | 04:29 PM
njmodi's Avatar
How about the cooling system. In this case - whats the best way to rid the cooling system of the oil/oil residue?
Old Apr 27, 2009 | 06:49 PM
draser's Avatar
Drain and refill.
Old Apr 28, 2009 | 06:35 AM
If there's a lot of oil, you could do this...
Drain, disconnect upper radiator hose, remove thermostat, leave lower hose open.
Use garden hose to flush lots of water thru block & then thru radiator.
If you can use hot tap water in the garden hose, that's even better.
Put hoses back, fill with distilled water.
Drain & fill again with distilled water, maybe again depending if your tap water is very hard.
Drain, then add NON-pre-diluted antifreeze to get proper mix.
There's probably 2 quarts that won't drain, so use the spec value for total coolant.
Njmodi, you'll need almost 1 gallon of antifreeze. Other years, whatever the book says.
Old Apr 28, 2009 | 12:20 PM
I think some cooling system flushes have non-foaming detergents to release oil from the system. Check w/ your local auto parts store.
Old Apr 29, 2009 | 01:03 PM
njmodi's Avatar
JimBlake/TexasHonda:
Thanks for your input. My issues are from last year - I had done coolant drain/fills 3 separate times - and mostly it's fine - but I do have a bit of oil residue that builds up in the coolant overflow reservoir. I'll try the cooling system flush from a parts store...
Thanks for your help.
jackkuykendall
Sep 18, 2011 08:50 AM
Shag Wagon
Feb 23, 2011 07:55 PM
Shag Wagon
Oct 12, 2010 03:37 PM
balaskonis
Apr 28, 2010 04:06 PM
htownfanatic
Jun 24, 2007 09:54 PM
