Flywheel-Good to Go?
Old Dec 16, 2014 | 12:51 PM
MGF 1996 Accord's Avatar
Default Flywheel-Good to Go?
I had my flywheel checked for flatness (was only off by 0.001), but since I am installing a new Exedy clutch I had a skim cut off the friction surface. After completing it was noted that there may be fine cracks in the hub area, so with a dremel I removed and noted that the they were not cracks as they disappeared quickly without much effort. Next to confirm I dye checked the entire flywheel for cracks (both sides) and it came back negative (I should have done that first).
Now I am left with four small area close to the hub (see attachment) where some material was removed.
I am interested in opinions on whether these minor areas can
1) be ignored, since it can be considered negligible due to material removed is so close to the center and should not have an adverse effect on balance.
2) I should try to balance with corresponding marks on the opposite side of the hub.
3) Need a new flywheel
Old Dec 16, 2014 | 01:17 PM
shipo's Avatar
Maybe it's just me, but it looks like you're way overthinking this thing. That flywheel looks infinitely better than many flywheels I've seen newly installed.
I say put it back in and forget about it.
SKHEMR
Feb 3, 2020 11:27 PM
GSXRAccordH22
Jun 14, 2012 06:06 PM
yamahonda06
Apr 13, 2006 01:19 PM
karls
Feb 7, 2006 06:05 AM
