fog lights won't turn off
Old Oct 2, 2012 | 02:10 PM
JohnnyQ's Avatar
Default fog lights won't turn off
Hey all, I'm looking for some help if at all possible, I have a UK 2004 2.2 diesel accord I imported into Ireland, excellent motor, miles are getting high but she is well serviced and running well. I'm having issues with my factory fitted fog lights, when turned on the only way to turn them off is by pulling the fuse.
Possibly a stuck relay issue? also not sure which relay controls the fog lights....
Any help wold be much appreciated, cheers all....
Old Oct 2, 2012 | 08:00 PM
Yes does sound like a stuck relay.
Is this a 2 or 4 dr?
In the US, the fogs were an add on.....here is the best I have at finding the relay : http://www.bernardiparts.com/Images/...s_AII27470.pdf
Good luck....again all I have, sorry
Old Oct 2, 2012 | 08:20 PM
jujuCO's Avatar
dont turn em on!
problem fix
Old Oct 2, 2012 | 08:25 PM
Originally Posted by jujuCO
dont turn em on!
problem fix
That is one way of looking at it....however I bet they are tied to the light switch on the UK version....been wrong before.
Old Oct 2, 2012 | 08:28 PM
jujuCO's Avatar
Thumbs up Love The UK!
See How Much
Old Oct 3, 2012 | 03:50 AM
JohnnyQ's Avatar
thanks Poorman212 for the diagram, relay position on the diagram looks like the correct position, there is a separate bolt on relay there but one large relay instead of two...
The control stalk in the cabin controls the fog lights, when on the green light on dash reflects this and when off the green dash light goes off, but the fogs stay on...
Lately the fuse has been removed so this is not an issue but in Ireland we have to do a national car test every couple of years and for this I need the problem sorted as if fog lights are installed they need to work... or else its a fail... could also remove the fogs if the problem is bigger than a stuck relay...
thanks for the help all...
Old Oct 3, 2012 | 03:52 AM
JohnnyQ's Avatar
Car is also a 4 door, cheers guys
Old Oct 3, 2012 | 11:54 AM
Thumbs up Fixed the Post For You lol
Hope you all like the edit job...I Did!
kennilope
Jul 15, 2022 12:21 AM
fudads
Feb 27, 2013 07:36 AM
Mzanuel513
Nov 15, 2007 05:14 PM
Ntegra
Oct 9, 2006 12:37 AM
