Front brake rotor size
Old Mar 16, 2017 | 10:48 PM
tak06's Avatar
Default Front brake rotor size
My '99 Accord V6 Coupe came with OEM 16" Alloy wheels, I understand that most came with the OEM 15" alloy wheels, does anyone know if the front brake rotor are the same size in both configurations and are interchangeable, I ordered a set of rotors & pads off the Auction site and it merely states that these rotors are for the '99 Accord V6 so I assumed that they would be the same for either 15" or 16" rims.
Thanks for your help.
Old Mar 17, 2017 | 07:44 AM
Yes. The difference should be 4-cyl vs. 6-cyl models. The 4-cyl cars have 4-lug wheels (& rotors).
Old Mar 17, 2017 | 12:58 PM
tak06's Avatar
Thanks Jim, I was aware of the bolt pattern, did some research and the only difference (excluding the bolt pattern) is that the 4 cyl. has 11.2" rotors and 6cyl. 11.8", apparently the rotor size is the same with 15" or 16" wheels. Sorry I should have done the research before posting.
CYB3R
Dec 23, 2014 12:15 AM
timster4
Nov 10, 2010 10:06 PM
Tony1M
Sep 22, 2010 06:54 AM
aznofthe205
Feb 11, 2009 06:15 PM
J2Performance
Jan 15, 2008 04:29 PM
