Front Brakes?????????????????????????
Old Aug 20, 2006 | 11:19 AM
FULL THROTTLE
Default Front Brakes?????????????????????????
I have had brake problems ever since I bought my 04 accord, The dealer has replaced the front rotors twice and turned them twice, I only have 37,500 miles, now my front tires have an out of balance issue and they won't admit the car has problems and replace the tires. Me and my wife both drive the car and we are not the type that ride the brake pedal. We barely put 12,000 miles a year on the car and this brake issue is really starting to tick me off, I feel like getting rid of it. has anyone had any issues with brakes??
Thanks,
Fran
Old Aug 20, 2006 | 11:43 AM
Default RE: Front Brakes?????????????????????????
Hi New Member..
If your dealorship gives you no help, then you have to go over there heads and call up Hondas Satisfaction line or e-mail them at there web site and tell them of the problem.
This usually gets the results you need.
Old Aug 20, 2006 | 03:04 PM
deserthonda's Avatar
ORIGINAL: FULL THROTTLE
Thanks,
Fran
have you had the wheels balanced ?? when you say tire have an out of balance issue what exactly do you mean ?? are tires separated ?? bulges? or just the steering whell shake at hwy speeds ??
are the tires wearing evenly ?
at 37,500 you cannot expect the dealer to give you new tires ,, most tires last about that long before you need to replace them anyways ,, have you had tire problems as well as brake problems while car was under warranty ?
as for the brakes i had the same issue as you,, i drive a 2003 accord and they had to replace the rotors and pads 2 times while car was under warranty,, as well as i resurfaced them once ,,,,,,,Honda came up with supposely updated brake pads that should eliminate that problem,
Old Sep 2, 2006 | 07:55 PM
hondadude's Avatar
I'd suggest that the next time you need pads try Wagner Thermal Quiet. They are a little bit softer compound, but won't have excess dusting nor will they glaze the rotor.
Old Sep 3, 2006 | 03:37 PM
Bullethole's Avatar
I have had similar problems in the past on my 94 and other cars. I have had the monkeys that rotate and balnace the tires reinstall the lug nuts with the same 800lb. gorilla air wrench they took them off with. This can warp the rotor. Lug nuts should always be tightened with a torque wrench or the very least a torque stick on the air tool. Usually around 100-110ft/lbs. Something to consider.
Rule #1 of troubleshooting. CHECK THE SIMPLEST THINGS FIRST!
Old Sep 3, 2006 | 05:15 PM
ORIGINAL: Bullethole
... Usually around 100-110ft/lbs. Something to consider.
Or maybe around 80 lbf*ft...
Old Sep 4, 2006 | 05:37 AM
marbro's Avatar
All ive ever done is tighten the lugs with a 1/4inch socket wrench by hand and never had a problem ^^ tho i would love to have that 800ft/lb impact gun ^_^
Old Sep 4, 2006 | 03:50 PM
YeuEmMaiMai's Avatar
does anyone know if the rotors are the same size as the 6th gen cars?
it seems like 03 and newer accords are suffering from "the front brakes are too small for the car" syndrome. This was a common problem with the 86 to 91 Ford Taurus/Mercury Sable cars. Either that or they are using cheap a$$ parts......
So the accords even come with 15" wheels anymore?
alphaney
Feb 12, 2022 10:14 AM
phantomgrey92
Dec 22, 2015 10:24 PM
ZionsWrath
Jan 25, 2009 11:19 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
