front driver turn signal does not work
Old Jul 18, 2012 | 09:15 PM
Sounds like a break in the GRN/YEL wire. For the right/pass side this is the power (again if my POS manual is correct). If the corner and rear are getting voltage from the same wire and the bumper/turn signal is not.....wire hunting time, yes I hate electrial issues
Old Jul 22, 2012 | 01:46 AM
x13darkmatter's Avatar
im not sure how its a break if i have continuity. i know i had the multimeter on the correct icon/ setting for continuity check ( the icon that looks like a wave and beeps when the two probes are touched together). thats when i get the roughly 1215 reading. if its not getting power then the only option is the turn signal switch... correct? or is there two metal canisters the wires go through that have resisters in them? somewhere online i read a car may have these i think.
Old Jul 22, 2012 | 10:01 AM
Guess I'm getting confused, not hard to do with me.
So the GRN/YEL wire has no voltage? Correct?
Old Mar 3, 2013 | 02:52 PM
Curtisg43228's Avatar
I had the same problem but I got lucky. I turned over the key turned on the turn signal and was pulling the bulb in and out, I then noticed that when the bulb was pulled on slightly the bulb then began to blink so I now know its the socket. Now I just have to figure out where to get one. Hope that helps and saves you money.
Gangsta101
Feb 10, 2013 01:50 AM
Damondelong
Jun 11, 2012 05:21 PM
accordgary07
Apr 10, 2011 07:47 AM
mjquillici
Mar 21, 2011 10:59 PM
nathan5603
Sep 14, 2010 08:35 PM
