Front seat removal- 04 Accord LX
Old Mar 1, 2010 | 08:29 PM
BigShelby's Avatar
Default Front seat removal- 04 Accord LX
Can the front seats be removed from an 04 Accord LX w/out tripping the air bag light? I would of course disconnect the battery first. I see there are wire bundles attached to the underside of the seats and I'm assuming those are part of the airbag system since I don't have power seats.
Old Mar 2, 2010 | 09:58 AM
hondadude's Avatar
Yes, before you dis-connect the battery have your radio code on hand.
The seat belt buckle has a switch in it that goes thru the SRS system.
Do you mean to remove the seats forever?
Old Mar 2, 2010 | 07:03 PM
BigShelby's Avatar
No I'm not planning to remove the seat forever. I just want to clean the PO dirt out and removing the seat is the easiest way.
So will the SRS reset itself if I reinstall and reconnect everything prior to reconnecting the battery?
Old Mar 2, 2010 | 07:10 PM
hondadude's Avatar
The only code it might throw is a 'low voltage' code.
But the reset procedure is pretty easy.
Just give a holler if ya need more info.
I think the SRS reset procedure is in the DIY Answers forum
OldFox
Apr 23, 2017 12:07 AM
JOE.G
Nov 4, 2012 08:48 AM
jmhwoodruff
May 21, 2012 04:48 PM
Mikebike125
Mar 30, 2011 08:19 AM
gooseegg2
Jun 12, 2010 07:25 AM
