Front tire suspension
Old Mar 30, 2008 | 08:46 AM
bhkcpa
Default Front tire suspension
My accord's front left tirerecently started to make a loud noise that sounds similiar to a loud valve tapping noise when bearing left or making left turns. Any suggestions on how to diagnose the problem? Thanks in advance.
Old Mar 30, 2008 | 09:17 AM
smaglik's Avatar
Default RE: Front tire suspension
sounds like a CV joint...
Old Mar 30, 2008 | 10:25 AM
bhkcpa
Thanks, is there any way I can test this for verification?
Old Mar 30, 2008 | 01:34 PM
It could be CV joint or wheel bearing.
CV joint will generally get worse w/ time, however the problem usually starts w/ ruptured boot which allows grease to escape. If you find a ruptured boot, CV joint is very likely.
Wheel bearing is best determined by elevating and rotating wheel w/ car in N. Any growling or vibration indicates a bad bearing. You may be able to feel vibration through the axle shaft,
Old Mar 30, 2008 | 03:05 PM
bhkcpa
ORIGINAL: TexasHonda
Thanks for your input, I'll start with the easier of the 2 and visually inspet the boot. I'll keep you posted on my progress. Regards
centralcalihonda
Mar 13, 2012 04:36 PM
Stoenr
Mar 29, 2008 09:23 PM
honda671
Oct 16, 2007 02:34 PM
I021600
Jul 9, 2007 01:30 AM
George Knighton
Jan 11, 2006 08:49 PM
