humming noise passenger front tire
Old Oct 14, 2007 | 02:28 AM
honda671's Avatar
Default humming noise passenger front tire
on my 95 accord while driving there is a humming noise coming from the front passenger tire,i just replaced the cv boots inner and outer but noise is still there.only when driving straight the noise is there,but when i make like a left turn it gets quiet,i also checked the wheel bearings and they seem to be alright,ball bearings dont show any chip or shavings.humming noise sound like a 4 wheel drive truck with big threads rolling down the highway...is it my aligment????
Old Oct 14, 2007 | 03:01 AM
RSM93HONDA's Avatar
Default RE: humming noise passenger front tire
More than likely you have a bad bearing. Buy a new one. It's pretty easy to fix. Hope this helps.
Old Oct 14, 2007 | 10:04 AM
deserthonda's Avatar
have you checked the tires ??
if tires are ok, most likely it could be a bad bearing , have a shop chk it out for you to make sure
Old Oct 16, 2007 | 12:43 PM
thaxman's Avatar
Sounds like exposed steel on the steel-belted radial to me. Of course that means the tire is worn beyond safe use & needs to be replaced immediately - it would be nearly useless if there was an emergency brake or manoever. And chances are if one's bad, both fronts are.
Old Oct 16, 2007 | 02:34 PM
rickyh22's Avatar
are tires new? or what cuz if the tires wear out unevenly then it does the humming thing cuz thats is what is happening to my car too....
bkklinger
Jun 27, 2016 02:32 PM
jrhess003
Jun 30, 2012 10:30 PM
camoo
Feb 10, 2010 11:48 PM
bsaas
Dec 10, 2009 05:25 PM
headpeace
Sep 13, 2006 08:31 PM
