Front Humming/high pitch Noise
Old Feb 10, 2010 | 09:56 PM
camoo's Avatar
Default Front Humming/high pitch Noise
I have a 2001 honda accord EX.
I had my tires rotated and some engine work done and once I got the car back a humming noise comes from the front of the car when I start to go in reverse or randomly happens when driving. It sounds like it is coming from the front right passenger door. It will happen for a little while then go away when driving at normal speeds.
The mechanic noticed it when they took it out to make sure they fixed the engine properly. To see if it was a wheel bearing they tried to wiggle the wheel when it was jacked up and it didn't move and they said that probably wasn't the culprit. They said everything looks fine and for me to drive it around to for a few days to see if it stops.
Since the tires were just rotated I don't think this is the problem as I have read about tires making noise if they are not balanced or not rotated often enough.
I checked the power steering fluid since I read it may be the problem but it is in between the min and max value.
It doesn't matter which way I turn the wheels when I reverse, the humming/higher pitch noise happens.
Can wheel bearings make a humming/high pitch noise when barley moving?
Any ideas???
Old Feb 10, 2010 | 11:48 PM
kris_loehr's Avatar
There is a dust shield behind the brake rotor that could give you that noise if it got bent and was rubbing on the rotor. I have seen this happen only if the steering knuckle or ball joints were removed or replaced and hit by a pry bar.
buzzbee
Nov 6, 2012 06:51 AM
banksmom2008
Jun 22, 2010 06:58 AM
petef23a
Aug 3, 2009 05:48 PM
bikener
Jun 6, 2008 03:06 PM
Jun 16, 2005 10:54 AM
