FTS help please
Old Mar 31, 2011 | 08:28 PM
scooterdad's Avatar
Default FTS help please
My check engine light is on took it to autozone and they said it is the FTS. I think it's the fuel tank sensor not sure but any way does anyone know where it located.
Old Mar 31, 2011 | 09:00 PM
There are two pieces of information that you need to provide.
1. What car do you drive?
2. What was the specific code (like P1234).
Old Mar 31, 2011 | 09:21 PM
scooterdad's Avatar
1996 Honda Accord I'll get the code for you tomorrow but the guy said it was called a FTS then he said fuel tank sensor. I'm thinking fuel tank pressure sensor.
Old Mar 31, 2011 | 09:24 PM
Get the specific code, because the description of the problem is too generic. It is probably an EVAP problem.
Old Apr 1, 2011 | 03:51 PM
scooterdad's Avatar
Here's the codes P0453&P1253 I'm buying this car from someone and wondering if I should be worry
Old Apr 1, 2011 | 04:51 PM
P1253 is a problem with the Vtec Solenoid Valve Circuit. That is on the cylinder head and the electrical connection is easily accessible.
P0453 is a problem with the Fuel Tank Pressure Sensor Circuit. That sensor is in the engine bay and easy to access.
You will have to do some tests with a volt meter to figure out what is going on. The problem with each code could be the sensor, the wiring, or the PCM.
Old Apr 1, 2011 | 06:20 PM
scooterdad's Avatar
Do i have to take the head off to access vtech solenoid. Do you think it mite be the return hole for the oil is clog. Where can i get a picture of where the FTP Fuel tank pressure sensor is. What the PMC
Old Apr 1, 2011 | 07:22 PM
The head does not have to be removed to access the Vtec. You can access the electrical connector easily. If you would have to remove the vtec, you would have to remove the thermostat housing. I don't know why the error code is there, but you will have to troubleshoot to find out.
PCM is the engine and transmission computer combined into one unit. On earlier accords (95 and earlier), they had an ECU and TCU.
The fuel tank pressure sensor is above the charcoal canister in the engine compartment. I think it is #31 in the picture below:
Old Apr 1, 2011 | 09:03 PM
scooterdad's Avatar
so you don't think it could be the return hole is clogged. Vtech problem
Old Apr 1, 2011 | 09:51 PM
Here's the cylinder head & the VTEC spool valve is #9. The picture is a bit misleading cause the actual location of that spool valve is over closer to the distributor-side.
The VTEC solenoid is #11, at the top with a triangle flange, 3 bolts, & a one-wire connector. Look for loose/corroded/dirty connection. Broken wiring?
An oil problem would show up with a different code for the VTEC oil-pressure switch (#13).
