Fuel filter change, Now...i have a problem
Old Jan 22, 2012 | 04:37 PM
Mipi2012's Avatar
I finally decided and bought a new egr valve and to my surprise the cel went away!but... I still got stuck with the feel like it's going to stall when coming to a stop...
Old Jan 22, 2012 | 05:13 PM
Check DIY forum for "iacv" and cleaning procedure. This is typically problem w/ low idle.
Old Jan 22, 2012 | 08:13 PM
And look for a post about setting the "base idle".
Old Jan 22, 2012 | 11:46 PM
Mipi2012's Avatar
after running out of ideas I finally decided and went for the new egr valve, and the good news...cel went away! but...the feel of stalling when coming to a stop was still there.
I then cleaned the throttle body with carb cleaner, and still no diference...SOo I changed the valve cover gasket and spark plugs and to my surprise, problem fixed!
Now Im just wondering where the the car should idle when on, and on (p)park? And when changed to (d)drive while holding the brake because, their little diferent.
But what a great weekend. Thank-you for your help/time and suggestions. Now to finish off with sparkplug wires and cap tomorrow and hopefully no more surprises...
Old Jan 22, 2012 | 11:49 PM
Mipi2012's Avatar
Ok will do thanks
Old Jan 23, 2012 | 06:55 PM
First, glad you got it
To answer your question, the book I have says 770 rpm's with a +/- of 50 in both N and in D4, so if it is in this range you are good, there will be "some" difference between N and D4....finish the other work before trying to adjust this. Also, before adjusting, I'd clean the IAC and the port to it.
Old Jan 24, 2012 | 09:02 PM
  #17
DanielC.Young's Avatar
I had this problem, too, my RPM getting as low as 100. I just tightened the throttle, and I don't recall it getting lower than 800 since. (It's really easy - just a few semi-turns of a nut, actually).
(Never had a code light up, though, so I never looked further).
Old Jan 27, 2012 | 07:42 PM
  #18
Mipi2012's Avatar
Default Thanks
Thank you for your generous help but I don't have that problem anymore, Yes!
Now I have another one
can you take a look and give me some advise on what to do
thank-you again
kc68
Jun 16, 2016 05:17 PM
rockhoundrob
Apr 11, 2014 11:41 AM
scooty1
Jun 24, 2011 06:30 AM
partsman1
Nov 5, 2010 07:25 PM
JohnnyWadd
Oct 1, 2007 05:56 AM
