Fuel Filter - Fuel Pump ??
Old Apr 13, 2021 | 06:32 PM
btartus's Avatar
Default Fuel Filter - Fuel Pump ??
1995 Honda Accord LX 2.7L Sedan
I just bought a Honda OEM Fuel Filter 16010-ST5-E02 direct from Honda on Amazon. It says made in Korea. is this ok? I was expecting a Japanese part. I saw on ebay a guy is selling 16010-ST5-922 Superceed to 16010-ST5-E02 which is made in Japan.
Fuel Pump - I picked up a OEM Original Fuel Pump on Ebay a year ago as a back up. Its in the original box, packaging, labeling etc. Got it from a man who bought it for his daughters car and never used it.
Should I have the Fuel Pressure tested before I have a new Fuel Filter installed and then after its installed to see if there is a difference? what is correct range for fuel pressure for this car? and can the Fuel Pump be tested before its installed into the car to make sure its working?
thanks folks!
Old Apr 14, 2021 | 06:07 PM
Fuel pressure should be 40-47 psi with the pressure regulator vacuum hose disconnected and engine running.
You can test the fuel pressure before and after fuel filter replacement to see if there is a difference. I'd lean towards not replacing any parts if you get a normal reading.
The made in Korea fuel filter is probably, since you got it from Honda. Honda sources OEM parts from many suppliers/locations.
I'd also not install a new fuel pump unless you are having issues with the current. I am almost positive that you have to drop the fuel tank to replace the fuel pump, so it is a lot of work and may give you no gains. If you are having an issue like hard starts, where the fuel pump check valve fails, then that certainly warrants replacing the pump.
Old Apr 14, 2021 | 06:10 PM
btartus's Avatar
Smile thanks!
thank you very much! exactly the info I needed! much appreciated!
Old Apr 14, 2021 | 06:12 PM
btartus's Avatar
you cant switch out the Fuel Pump through the trunk. that was I was led to believe that you can access through the trunk.
Old Apr 14, 2021 | 07:28 PM
There is no access panel to the fuel pump on the 94-97 accords the back seat/trunk.. You will have to drop the fuel tank to replace the fuel pump. The access panel in the trunk returned starting with the 1998 Accords.
Old Apr 14, 2021 | 07:40 PM
btartus's Avatar
again, thanks! your a wealth of knowledge my friend! be well!
Old Apr 23, 2021 | 10:24 AM
btartus's Avatar
so I had the fuel pressure tested before replace and it was 40-41 psi. I had the mechanic replace the cheap Chinese filter with the OE Fuel Honda Filter. car drives great!
rockhoundrob
Apr 11, 2014 11:41 AM
93Accord2.2
Jul 25, 2013 05:46 PM
KY98Accord
May 19, 2011 01:47 AM
Tarsis
May 16, 2006 03:58 AM
driver93
Dec 19, 2005 05:22 PM
