Fuel injector cleaning?
Old Aug 1, 2012 | 07:53 AM
JCS's Avatar
JCS
Default Fuel injector cleaning?
93 Accord 4 cylinder MT with 166K miles... Every time I go to get my oil changed they want to clean my fuel injectors. Is this something I need to do and, if so, how often?
-John
Old Aug 1, 2012 | 07:24 PM
I don't think that you need that service done.
Old Aug 1, 2012 | 09:01 PM
basket_case's Avatar
I'm probably the exception, but I generally remove the injectors and have them ultrasonically cleaned at around 100K. I've been talked into the injector service where the injectors stay installed, but it didn't seem to do any good. I removed them and had them cleaned and I noticed an improvement.
Some people will say not to go looking for problems to solve if you don't have any problems and there's something to that. In my case, I have ended up chasing issues and cleaning the injectors was either convenient at the time or one of the possible solutions to a problem I was experiencing. As I'm getting older, I'm leaning toward the path of least resistance - if there's no problem, you don't need a solution. I guess the point I'm trying to make is that if you are going to clean them, removing them and having them cleaned ultrasonically is the best way. It'll cost more if you pay someone to do it but you'll get better results.
fortyfootelf
Jan 22, 2010 07:15 PM
fatboy77
Nov 29, 2007 09:22 PM
FlyLow
Dec 4, 2005 10:45 PM
dinzer
Aug 9, 2005 11:17 AM
Mar 1, 2005 09:39 PM
