FUEL SYSTEM
Old May 19, 2005 | 12:54 AM
Alekat's Avatar
Default RE: FUEL SYSTEM
Actually - both filters are not too difficult to replace and inexpensive. Usually the strainer in the tank is not a problem unless the fuel cap is left off and some serious contamination enters past the spring loaded flap.
Tip of the month: DO NOT let the vehicle run out of fuel. The fuel pump motor is cooled by gasoline. Allowing the tank to run dry can over heat the motor. Should it fail, it can cost from $350 to $700.
Believe it or not.
Old May 21, 2005 | 11:44 PM
Burn69's Avatar
ya, literally HOT tip....hehehe
Old May 22, 2005 | 11:59 AM
Evlampius's Avatar
ORIGINAL: Alekat
Believe it or not.
Hey mate . I'm surprised to see another smart person on the forum that is actually know something. Not manypeople know that Gasoline takes heat away. Actually that is how the thermistor inside the gas tank knows when to light the low fuel level light when the tank is nearly empty. [sm=icon_cheers.gif]
Old May 23, 2005 | 06:00 PM
6thgen's Avatar
ORIGINAL: Evlampius
ORIGINAL: Alekat
Believe it or not.
I resent that.
Old May 23, 2005 | 06:21 PM
Evlampius's Avatar
hey - and you ofcorse [sm=hail.gif]
Old May 23, 2005 | 09:37 PM
6thgen's Avatar
thank you...[sm=groupwave.gif]
Old Jun 18, 2005 | 06:00 PM
  #17
hoffy
Yikes, I just ran out of Fuel in my '96 Accord. How will I know if I've done damage to my fuel pump?
I'm new to this forum and I appreciate any help/suggestions.
Cheers
Old Jun 19, 2005 | 06:12 PM
  #18
Alekat's Avatar
If it won't start
If it runs poorly - especially when engine is warmed up.
Another tip: IF you run it dry - after adding gas - and before you try to start the vehicle - turn the key to ON for about 10/15 seconds to allow gasoline to pump up to the engine - then try to start.
Believe it or not.
live2rice
Sep 3, 2012 12:34 PM
sajeed
Jul 3, 2008 12:36 AM
poser_pilot6
Nov 10, 2006 08:40 PM
skytech76
Oct 26, 2006 11:08 PM
rogersah
Mar 22, 2005 02:56 AM
