Fuse #12 under hood
Old Jul 17, 2010 | 06:42 PM
Lafrog's Avatar
Question Fuse #12 under hood
I have a 98 Accord V6. The battery keeps dieing overnight. We have tracked the problem to the #12 position Fuse in the Fuse box under the hood. It is labeled Accessory and Backup. Does anyone know what is run by this fuse?
Old Jul 17, 2010 | 09:45 PM
hondadude's Avatar
That might lead a person to think the accessory socket and back up for radio, clock, and ECU.
The amp draw across that fuse should make a test light glow dimly.
Old Jul 18, 2010 | 06:29 AM
Lafrog's Avatar
There is also an accessory in both inside fuse boxes. What is an ECU? I had a car starter hooked up a few years ago. I am wondering if it could be powered through fuse #12 under the hood. I have shut off the toggle switch fo rthe car starter and found my car battery still dead in the am. My Neighbor tracked the power drain to the #12 under the hood. I am assuming the accessory socket and radio are the fuses labeled accessory in the inside fuse box.
Old Jul 18, 2010 | 08:21 PM
Originally Posted by Lafrog
... What is an ECU? ...
Engine control unit. Honda officially calls it a PCM = Powertrain Control Module. It's the combined engine/fuelinjection computer combined with the transmission control computer.
moddisonj
Dec 18, 2012 10:56 AM
bochincheboy
Apr 21, 2008 01:40 AM
daddy
Nov 30, 2006 03:37 PM
dtycoon2003
Aug 11, 2006 08:29 PM
boo623
Jul 9, 2005 07:30 PM
