short on ecu fuse under dash
Old Apr 20, 2008 | 12:21 PM
bochincheboy
Default short on ecu fuse under dash
I have a 91 honda accord which i recently purchased that needed some TLC. When i bought the car it had an erratic idle and the speedometer didn't work. I rebuilt the head and replaced all the gaskets cause it was mixing water with oil, and the clutch wasn't to good so i replaced that also. After that some electrical component's stop working eg; automatic seat belts, fuel gauge, temperature gauge, RPM gauge, and power windows. I started checking my fuses and all of them work except for the ECU fuse under the dash, i put one with a higher amperage rating but it keeps blowing, but right before it blows in that split second everything that doesn't work starts to work, please help all help will be greatly appreciated.
Old Apr 20, 2008 | 03:44 PM
Default RE: short on ecu fuse under dash
Something past that fuse is grounded and drawing too much current. I don't have the wiring diagrams for a 91 accord. There is a shop manual for a 90 accord that you can find in the online manuals thread in the DIY section.
You are going to have to find out what circuits are routed through that fuse and start testing for wires with a volt meter, or inspecting the wires individually that draw current from that fuse.
Old Apr 21, 2008 | 01:40 AM
bochincheboy
do you think it could be a wrong wire grounded that shouldn't when i dropped the tranny, or when i snatched out the head
moddisonj
Dec 18, 2012 10:56 AM
tvandentop
Sep 17, 2011 06:42 AM
Lafrog
Jul 18, 2010 08:21 PM
poorboy_616
Dec 4, 2009 09:29 PM
