Fuse Problems
Old Oct 24, 2010 | 10:31 PM
Animeop's Avatar
Default Fuse Problems
Problem started last Thursday when the fuse labeled ECU on the internal fuse box (7.5) blew and the car ran the battery down to nothing i didn't realize it at the time so i change the fuse charged the battery, however later that day a came to discover that every time i start the car that fuse blows and the car runs till the battery runs to zero, i know it not the alternator or the ECM since i had the alternator tested and bought a new ECM, so I'm retty much lost as to why the ECU fuse blows instantly. It should be noted however that what ever is blowing the fuze will blow up to a 20, i know you shouldnt put larger fuses but i had to get the car home.
1996 accord ex, cold air intake, Bosch plugs
Old Oct 24, 2010 | 10:46 PM
I find it strange that the battery got drained.
There are several items protected by that fuse. The PCM, the stereo/radio, and the clock.
I would unplug the stereo and clock. See if the 7.5 amp fuse blows.
Old Oct 24, 2010 | 11:02 PM
Mdschmidt's Avatar
the ECU fuse should be a 15 amp fuse not a 7.5 amp... im having the same problem but it doesnt drain my battery the car just shuts off and wont start again, it just cranks
Old Oct 24, 2010 | 11:06 PM
Animeop's Avatar
its the one on the interior fuse box, although i think that its labeled wrong because from what i can tell the Altinator and A/C run through it
Old Oct 24, 2010 | 11:08 PM
Animeop's Avatar
Also To PAhonda, my stereo isn't connected properly, its run through the 30 Amp wiper fuse were as i had a problem with the yellow power wire when i first got the car
Old Oct 25, 2010 | 12:06 AM
Animeop's Avatar
Old Oct 25, 2010 | 12:36 AM
Animeop's Avatar
also i tried to disconnect the stereo and it still blows
Old Oct 25, 2010 | 12:51 AM
I was assuming you were talking about the 7.5 amp backup/radio fuse. Is this the fuse box inside the car or in the engine bay?
Which fuse number is blowing in the attached diagram. The picture is of the one in the cabin.
Old Oct 25, 2010 | 12:54 AM
Animeop's Avatar
number 4
Old Oct 25, 2010 | 01:29 AM
That fuse is different than the one I was thinking. Is your car an automatic or manual transmission?
That fuse protects:
Charging system light
Cruise control main switch indicator
Cruise control unit
Alternator
EGR control solenoid
Transmission computer
Engine mount control solenoid valve
ELD unit
Radiator fan control module
Fuel injection air (FIA) control solenoid
Intake air resonator (IAR)
Now it makes sense that your battery will drain, because your alternator is on that circuit.
Download the 94 shop manual from the spooner link in the online manuals thread in the DIY section to locate those items. Does the fuse blow immediately when you turn the key to the II position?
