Fuse Problems
Old Oct 25, 2010 | 01:34 AM
Animeop's Avatar
Originally Posted by PAhonda
That fuse is different than the one I was thinking. Is your car an automatic or manual transmission?
That fuse protects:
Charging system light
Cruise control main switch indicator
Cruise control unit
Alternator
EGR control solenoid
Transmission computer
Engine mount control solenoid valve
ELD unit
Radiator fan control module
Fuel injection air (FIA) control solenoid
Intake air resonator (IAR)
Now it makes sense that your battery will drain, because your alternator is on that circuit.
Download the 94 shop manual from the spooner link in the online manuals thread in the DIY section to locate those items. Does the fuse blow immediately when you turn the key to the II position?
she is auto unfortunatly, it only blows during or imediatly after the car is started so in the III positon
Old Oct 25, 2010 | 01:41 AM
Animeop's Avatar
omg, idk why it wont post but its an auto, fuse blows in the number III position, its fine in the number II position
Old Oct 25, 2010 | 01:42 AM
Animeop's Avatar
righty... ignore that it just wasn't appearing for me
Old Oct 25, 2010 | 01:44 AM
You had a double post, so I don't know what the posting problems are.
I would unplug the alternator and try to start the car. See if that fuse blows.
Old Oct 25, 2010 | 01:46 AM
Animeop's Avatar
Ground also or just the main plug?
Old Oct 25, 2010 | 02:09 AM
Animeop's Avatar
Ok well i opted for the both option and im down to just 15 fuses but either way it still blows right away -.-
Old Oct 25, 2010 | 02:26 AM
  #17
Tracking down shorts is a pain, as you will find out. Do you have a volt meter?
You can try to unplug most of those items (except the PCM) and see if the fuse blows. That shop manual will show you where all that stuff is located.
Your car has a PCM, so I do not think it has a separate transmission computer like my 95.
Have you done any work on the car prior to this electrical problem?
Old Oct 25, 2010 | 02:30 AM
  #18
Animeop's Avatar
only thing I've done is add 2 10'' subs, stereo which as i previously stated is wired into the 30 fuse for wipers, and change the upper control arms, however I've had a Toyota pickup tht had a similar problem except it turned out to be the distributors ground
Old Oct 25, 2010 | 04:53 AM
  #19
Animeop's Avatar
ummm... im looking through this service manual and its showing that the TCM is mounted nect to the ECM... but ive replaced the ECM and there wasnt anything mounted directly next to it...
Old Oct 25, 2010 | 02:53 PM
  #20
I mentioned this in my last post. The 96 has a PCM, so it will have one computer. The 94 is very similar to the 96, so those other items on that fuse should be the same between the two cars.
