Gang...
Old Aug 25, 2010 | 08:13 PM
dpiersma's Avatar
Default Gang...
...I have a 2005 Accord and the other night the wifeski left the driver and passenger windows open and of course it rained. She she got and turned the key to acc and closed them. From that point on, the only window that works is the drivers window. The others worked sporadically for a day and now just the drivers window works. I tried at each location in addition the the control panel on the drivers side arm rest and no go. It seems to have dried up fairly well as I thought maybe the circuit board got wet but still nothing. Any help would be greatly appreciated.
Old Aug 25, 2010 | 09:37 PM
I would check the fuses just to be sure that isn't the source of the problem.
I'm not as familiar with the newer accords. I think the the driver's side window switch has the control unit in there as well. The water could have damaged that. If I had to guess, that would be the source of your problem. I would try to pick one up from a junkyard, because it looks like a new switch is over $100.
Honda4me
Aug 24, 2010 10:12 AM
Ron505
Mar 20, 2008 01:52 PM
