Gas light issue, possible fix
Old Dec 29, 2012 | 12:07 PM
crazyhade's Avatar
Default Fuel light issue, possible fix
Ok I know there have been lots of posts on here about the gas lights, but this one is about the 98-02 years. I want to know if there is a fix. I know the problem is my thermistor, I pulled the pump out and broke off the thermistor. I took it apart and was trying to find a fix but it was too far gone, when i got into the case pieces fell out. I may have found a fix but idk. Im thinking of using a switch from an extra water pump i have. Its a small box that contains a float and its own tank that you drain water into from a hose or small pipe. I took the switch out and tried it with a batery under water and it works fine but im a lil worried about leaving it in the tank with gas all the time in there. I looked online and at radio shak but cant find a thermistor to replace the oem one, and i had the switch laying around so its basically free. Has anyone found a fix? At this point I dont care about the light since the guage works fine, but I like everything to work on the car.
Attached Thumbnails Gas light issue, possible fix-imag0022.jpg   Gas light issue, possible fix-imag0056.jpg   Gas light issue, possible fix-imag0058.jpg   Gas light issue, possible fix-imag0070.jpg   Gas light issue, possible fix-imag0071.jpg
Old Jan 3, 2013 | 01:21 AM
crazyhade's Avatar
bump.
Old Jan 3, 2013 | 09:01 AM
I guess I would just be careful in general about putting alternate electrical devices inside the fuel tank. Be very certain the contacts are rated OK for that lamp; it's probably 5watt or less.
But other than that, it looks like a good fix.
cOrKinsa
Mar 3, 2009 10:05 AM
clutch811
Feb 19, 2009 11:38 AM
jphill0
Jun 2, 2008 09:49 PM
david9h
Jun 1, 2008 07:00 AM
platenuts
May 23, 2008 01:39 PM
