Gas stopped early
I was fillin up today ($3.56/gal for plus) and it stopped before my tank was full. Is something wrong here? It needed about 11-12gal to be full and only got 8gal. I have filled up at that pump before and didn't have any problems.
I think where sir_nasty is getting at is to not rely on your gas gauge.
Pay attention to your mileage as you drive to get a feeling of when you should be out of gas, and to determine how much you've used.
ORIGINAL: sir_nasty
what are you using as a basis to determine how much fuel your car should take?
It is likely the pump. Even if you have used the same pump before, no pumps are perfect. I have been to several that will stop a bunch of times and I have to hold the lever instead of locking it. I think it has to do with the underground tank getting low on fuel or something.
ORIGINAL: klrspz
I've been pushing my ride real hard, I might be lucky if i make it to 300mi... also, wow.. 3.56/gal!!! it's 2.89 here in dallas.. where do you live?
