Gaslight.
Old Jun 4, 2010 | 04:59 PM
darn yankees's Avatar
Default Gaslight.
I have a 2001 Honda Accord EX V6 and my gaslight stays on while I'm driving. I checked the gas cap and its ok and I also filled the car with gas to make sure the needle was working. I also disconected the battery to see if it will reset but nothing. Can someone please help me? Thanks.
Old Jun 4, 2010 | 06:25 PM
That light is controlled by the fuel gauge sending unit in your gas tank. In the trunk (or maybe under the back seat), there should be a 4-pin connector underneath an access panel.
Unplug that connector. If the light turns off, then there is a problem with the sending unit. The black wire coming out of that connector is bolted to a ground nearby. You car may not be set up like that. Clean that ground with some sandpaper, then re-tighten.
If the light stays on after you unplug the connector, then the yel/blu wire is grounded somewhere between the sending unit and the cluster.
