Got 22mm of rotor left
ORIGINAL: MALSR
With only 22mm left I was wondering if it would be just as economical to replace the rotors with new ones since thet are rather difficult to remove?
No need to replace rotors if the ones on the car are still thick enough to be resurfaced,, and when done still be above specs,,
And absolutelly ,, make sure that when resurfacing rotors always use a shop that has the ON CAR LATHE
With 22mm left resurfacing them could bring them down to the 21mm limit. But even if it doesn't you'll be having to replace them sooner rather than later. I would say it would be best to simply get new rotors now and be done with it.
ORIGINAL: MALSR
My brakes are pulsating so i figure the rotors need to get refinished. With only 22 mm left should I just replace them or is there enough left to get the turned??
ORIGINAL: deserthonda
