Got 22mm of rotor left
My brakes are pulsating so i figure the rotors need to get refinished. With only 22 mm left should I just replace them or is there enough left to get the turned??
RE: Got 22mm of rotor left
Minimum is 21mm if i remember right. Should be plenty left to refinish them.
With only 22mm left I was wondering if it would be just as economical to replace the rotors with new ones since thet are rather difficult to remove?
ORIGINAL: MALSR With only 22mm left I was wondering if it would be just as economical to replace the rotors with new ones since thet are rather difficult to remove? |
I just found a place that has an on-car lathe for 75$...I'll try that and see if they last for a while
Better of getting new rotors in my opinion. Some good name brand ones.
No need to replace rotors if the ones on the car are still thick enough to be resurfaced,, and when done still be above specs,,
And absolutelly ,, make sure that when resurfacing rotors always use a shop that has the ON CAR LATHE |
With 22mm left resurfacing them could bring them down to the 21mm limit. But even if it doesn't you'll be having to replace them sooner rather than later. I would say it would be best to simply get new rotors now and be done with it.
ORIGINAL: MALSR My brakes are pulsating so i figure the rotors need to get refinished. With only 22 mm left should I just replace them or is there enough left to get the turned?? |
ORIGINAL: deserthonda No need to replace rotors if the ones on the car are still thick enough to be resurfaced,, and when done still be above specs,, And absolutelly ,, make sure that when resurfacing rotors always use a shop that has the ON CAR LATHE |
