Ground location for main relay on '93
Old Apr 28, 2015 | 10:19 AM
tashier's Avatar
Default Ground location for main relay on '93
Question. Working on a '93 accord with main relay problem. Relay is not pulling in and I diagnosed it to a bad ground. When I jumper black wire to ground car fires right up. Does anyone know where this wire is grounded? Links to wiring diagrams?
Thanks.
Old Apr 28, 2015 | 10:31 AM
Main relay's black wire is routed and grounded at G101, located on the thermostat housing.
Old Apr 28, 2015 | 10:45 AM
tashier's Avatar
Thank you! I'll check it out.
Old Apr 28, 2015 | 10:49 PM
tashier's Avatar
That was it. Bolt was loose.
Old Apr 29, 2015 | 02:36 PM
That one loose bolt can cause a host of confusing electrical problems. Glad it was an easy fix.
Dieskyver
Dec 8, 2014 06:30 PM
snerty32
Oct 17, 2012 11:22 AM
skareb
Aug 26, 2010 06:41 AM
Planefreak
Sep 17, 2007 11:20 PM
Prizma
Aug 25, 2007 02:24 AM
