h22 head on f22 block?
Old Jul 12, 2010 | 02:04 PM
dylan71971's Avatar
Default h22 head on f22 block?
Alright so i have a 92 accord, and i'm wondering if i can fit an h22 head on my f22 block, or if theres another dohc head that would fit the f22 block, thanks for anyone who may have help or advice
Old Jul 12, 2010 | 05:07 PM
I think that it can be done, but it is not a simple swap. I think people call it a G22 engine. I don't know how much hp you will gain from it either.
Old Jul 12, 2010 | 06:36 PM
dylan71971's Avatar
ive looked more into it and its supposedly pretty easy, all most people say u gotta do is plug up some oil passages on the head, but i wanna know all the little things you gotta do to accomplish it
Old Jul 12, 2010 | 07:59 PM
g22cd5's Avatar
Supper Moderator
Why do you want to swap to H series head? just to have vtec? or just to have a DOHC engine? IF so then it is a total pointless swap you MIGHT gain 2hp if your lucky. . What are your goals for the head swap?... The f22a heads flows much better than the h series heads. So if you arnt boosting or bumping up your c/r then you will spend money for a pointless head swap.
Old Jul 13, 2010 | 07:07 AM
dylan71971's Avatar
what is there i could possibly do to increase hp for around 1k? i thought id gain more than 2 haha
Old Jul 13, 2010 | 09:22 AM
g22cd5's Avatar
Supper Moderator
well if you have a grand to drop then you can do the h22 vtec head swap. Then you would need new pistons to raise your compression ratio to take advantage of vtec. Pistons will run you about $500 head will run you about $100-200 depending where and who you buy from. Then buy bolt ons...search on accordinlydone.com and hotda-tech.com for "PirateMcFred" he is the G series masta. He has made some good power with n/a g series. He has one build that is make same HP as a stock h22 with more TQ. So if this is the rout you wanna go look him up he has tons and tons of good info.
1991AccordLX
Jul 2, 2009 07:20 PM
jerrym88
Jun 1, 2009 11:20 AM
AbaZ
18
Jul 16, 2008 10:23 PM
SpanishN00b
Jul 29, 2007 07:11 PM
EMEX
Mar 21, 2007 02:08 AM
