half axles
Old Apr 22, 2007 | 11:40 PM
haphaight
Default half axles
my step son and i have been Eight hours already feebly attempting to install both half axles on a '98 Accord that has never been touched in this area, hence Every bolt/nut is tighter than bark on a tree. this car has a Wish Bone on the lower control with a Three inch gap and the "hubs" on the axles are 3.75",so they wont slide through, that would be to easy, We can not for the life of us get the bolt out of the Wish Bone attaching it to the control arm. Do we need a Spring Compressor? I tried heat and the result is i now have ordered the rubber bushings cuz the one is sort of melted,phue, just love the smell of burnt rubber.. but we lubed, tapped,and BEAT this thing and it will not budge. so have mercy on us and please enlighten us. i thank you in advance for your time and wisdom.
Old Apr 23, 2007 | 05:57 PM
deserthonda's Avatar
Default RE: half axles
like you reside in snow country .. we are talking about the lower bolt correct ??
I use to live in Wisc and those bolts froze real bad.. I had a crap load of these ..
anyho,, once you remove the nut . get a 17 mm socket with a pry bar , heat up the bolt with a torch and gently go back and forth on the bolt,, make sure to watch at the other side of the bolt where the threads are to make sure that the complete bolt is spinning and not just 1/2 of it and twisting off ..
Old Apr 23, 2007 | 10:00 PM
haphaight
thanks for your reply, i think i'll have to cut the pig out of there. the sleeve inside the bushing appears to be bonded to the bolt, you can see it turn inside the rubber. so i guess it's off to the store for replacment bolts. Q? do i need a spring compressor?
Fibercation.com
Jul 8, 2008 11:51 PM
thesaintval2000
Jul 5, 2008 04:34 PM
BostonPuppyDawg
Jun 25, 2007 08:57 AM
sickaccord
Feb 18, 2007 10:30 PM
brownstreak
Apr 7, 2006 03:30 AM
