hard brakes
Old Aug 29, 2013 | 04:37 PM
Originally Posted by ActAccordingly
It sounds like you need to bleed the brake lines, you're describing what sounds like air in the system.
How to bleed brakes using the " One person " method - YouTube
Problem w/ this bleeding procedure is requirement to have tight seal at bleeder/caliper connection (grease is only option) and bleed hose/bleeder (pain to clamp each bleeder). When you release the brake pedal, negative pressure occurs in caliper, and if any leaks, air will be pulled into system leading to soft brake pedal.
Vacuum bleeding w/ vacuum hand pump however pulls the brake fluid out of system and system always has higher internal than external pressure. Consequently, no air can enter brake fluid in caliper. You will see air in fluid pulled from system (pulled in around around bleeder), but none in caliper. I've used vacuum bleeding on a number of cars w/ excellent results. I use a cheap vacuum bleeder available from Harbor Freight and have been pleased w/ tool.
Old Aug 30, 2013 | 08:13 AM
wunderbra's Avatar
Originally Posted by Dr. Drivability
next, i would try to bleed the system. make sure fluid flows freely from all corners. could be a restriction in the system.
Thanks for the suggestion, but I bled the brakes when I did the pads, just to be sure. Anyway, I keep clean fluid in the system annually with a pressure bleeder. They are great btw, if you have ever used one, you'll never go back to the vacuum or pedal pump method. They are really good for changing fluid. as TexasHonda alluded to, it is possible the pads on my other wagon are very soft and strong. They were on the car when I bought it a couple years ago. Guess I'll live with it.
Old Sep 5, 2013 | 12:13 PM
I thought this thread pretty much covered brake bleeding procedures, but I stumbled across a new variation that I found very attractive for DIY solo brake bleeding. See youtube video.
The kinked tubing to prevent air suction is very innovative!
Old Sep 6, 2013 | 05:31 PM
wunderbra's Avatar
Pretty inventive. The power bleeder is really the way to go, especially if you change fluid regularly. 50 bucks for a store (online) bought one or make your own:
The DIY $20 brake bleeder
alphaney
Feb 12, 2022 10:14 AM
phantomgrey92
Dec 22, 2015 10:24 PM
ZionsWrath
Jan 25, 2009 11:19 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
