head gasket?
Old Aug 8, 2019 | 07:02 PM
ftp247's Avatar
Default head gasket?
If I have coolant inside valve cover,but when I drained my oil it doesn't have any coolant at all could it be a bad head gasket or could coolant got in there thru somewhere else?I have a 1999 honda accord ex 2.3 4 cylinder engine.
Old Aug 8, 2019 | 09:54 PM
Welcome! The "new member" area is mostly for welcome & introduction posts. So I'm moving this to General Tech where you'll get more help.
First of all, how do you know it's coolant? Smell? Is there enough to see the color?
Its common for water to condense in there, like dew on everything outdoors. It dries out when the engine warms up, but if you never drive any distance it can build up.
Seems like a bad headgasket would be the first thing to suspect. You might want to pressure-test your cooling system to verify that. Or at least look for oil in the radiator - it makes a funky mixture like curdled chocolate milk.
thunder_x
Jul 9, 2007 11:57 AM
dodins
Mar 18, 2007 08:10 PM
samuel_c038
Mar 10, 2007 06:50 PM
noboundaries6289
Feb 21, 2007 10:30 PM
corr04
Oct 31, 2006 10:02 AM
