Headlight Help
Old Feb 22, 2011 | 08:25 PM
whitneywny's Avatar
Default Headlight Help
My low beam on my Honda Accord has been dim for a week or so, I went and bought a new bulb and put it in and it is still dim. I am afraid of getting pulled over, but I dont know what the problem is. Can someone help me, or tell me what I can do that is least expensive??
Old Feb 22, 2011 | 10:50 PM
Read the Sticky post on the top of the gen tech help. Specifically on the section on what car you drive.
Old Feb 23, 2011 | 06:07 AM
whitneywny's Avatar
Im sorry I forgot to post that. It is a 1998 honda Accord, 2 door, 6 cyclinder.
Old Feb 23, 2011 | 05:49 PM
Have you checked the connector pins-clean/tight/ect. From there double check the ground wire for a good connection (resistance to ground)...then of course check the power wire.
Old Feb 23, 2011 | 06:56 PM
Check the fuses in the under-hood fuse box. Yes, it can be the fuse even if it lights up. They should be 20 amp fuses. You didn't state which side, so I highlighted both fuses.
mamtsberg
Mar 17, 2010 09:15 PM
Fez
Mar 10, 2007 05:01 AM
live2rice
Oct 20, 2006 03:14 AM
hondakidpr
Jul 13, 2006 04:43 AM
