Headlights
Old Aug 12, 2017 | 09:02 AM
Fyredan's Avatar
Default Headlights
I have a 2009, I can't get the headlights bright enough. It's great out the sides but straight ahead is terrible. I have 8000 lumin bulbs but no help
Old Aug 12, 2017 | 12:20 PM
More information is needed first.
Is this a sedan or coupe?
What is the brand, part number and type of bulbs?
Old Aug 14, 2017 | 09:19 AM
Fyredan's Avatar
I have used sylvania (several lumen levels) and recently bought G1 LED's. The same problem with both bulbs.
Old Aug 14, 2017 | 10:27 AM
Were they all LED lamps? Those hardly ever have the correct location of the actual light source so they don't work correctly with the shape of the reflectors & lenses.
Old Aug 14, 2017 | 01:02 PM
shipo's Avatar
If the housings on your car weren't designed for LED bulbs, then the odds are very high replacing the OEM bulbs with LEDs will negatively affect your light output. I recommend going back to OEM style bulbs and call it a day.
If you really want to convert to LEDs, then you should buy a new set of after market housings designed for LEDs (if such a housing exists).
Old Aug 14, 2017 | 01:25 PM
You did not indicate whether your car was a sedan or coupe, for the low beams, they use different bulb types and headlight housing.
The coupe are projector type, whereas the sedan are reflector type.
Had to do a google search, but, you probably bought JDM Astar G1 bulbs. I do not know if these LEDs have a beam angle adjustment capability. The beam angle is critical especially when used in a reflector type housing.
I currently use PIAA 9005/9006 LEDs bulbs, which have adjustable beam angles. They do not and cannot increase the beam throw; but, have better visibility than than any halogen bulbs I tried (including Philips 9012 HIR halogen bulbs). The PIAA costs more; but, are a good quality safe bulb, no glare.). In rain, the white light isn't that useful though.
Pilot Mobbin
Jan 30, 2013 07:18 AM
playav
Dec 4, 2005 04:43 PM
hjl47
Oct 24, 2005 10:28 PM
9JordonAccord9
Sep 29, 2005 11:19 PM
sk8misro
Aug 16, 2005 07:58 PM
