Heated Back Glass Connections
Old Oct 23, 2013 | 11:26 AM
balbert's Avatar
Smile Heated Back Glass Connections
Hello I have a 2009 Honda Accord 2 door coupe which recently required the heated back glass replaced.. I picked up a used glass from a local recycler and had it installed only to find the heated grid is not working. I contacted the glass installer and he is "not sure" if he hooked up all the connections when replacing the glass. I am quite a ways out of town and the thought of having to drive back in for him to check connections is not really appealing. However, I can not seem to find the wiring connections for the heated glass and assume I am going to have to remove some panels to find them. Would anyone have some idea where to start on this project...essentially i want to find the connectors and verify they are terminated or not.
Thanks for any help.
Old Oct 23, 2013 | 12:09 PM
Hi new member..I moved your post to the get help area for you.
Welcome to the HAF..
Old Oct 23, 2013 | 12:28 PM
There are the airbags in those areas and the rear defogger connectors on both sides are behind the C pillar trim covers (ground on right side, power on left side). Let the glass installer handle it.
This thread has some information:
https://www.hondaaccordforum.com/for...working-56930/
icanbne1
Nov 9, 2013 02:19 AM
dav8948
Jan 27, 2012 09:35 AM
03accord2.4
Jul 9, 2008 01:49 PM
yoggi
Feb 1, 2008 07:51 PM
emaxxman
Mar 20, 2006 02:59 PM
