Heated seats 2003 accord tourer 2.0 VTEC
Old Aug 18, 2015 | 06:39 AM
kwakers's Avatar
Default Heated seats 2003 accord tourer 2.0 VTEC
Hi all techies
heated seat issues, does anybody know if this a common fault as my drivers side seat doesn't heat or is it just due to previous fat but's causing it to break down i know there was a recall on heated seats a few years ago on the Accords over here in GB what do you'll think?
Old Aug 18, 2015 | 10:20 AM
Turtlehead's Avatar
Just disconnect the connector under the seat, test that there is power with the switch on, if no power then check that there is power to the switch, if so then it is the switch and if not then the power issue is before the switch. If there is power to and out of the switch then it is either the unit within the seat or a bad ground.
NebraskaSun
Jun 21, 2013 12:25 AM
senorbuck
Mar 19, 2008 05:26 PM
yoggi
Feb 1, 2008 07:51 PM
nahfuten
May 31, 2006 12:35 AM
