hello big puddle of coolant
Old Aug 15, 2008 | 04:55 PM
maro's Avatar
Default hello big puddle of coolant
so It looks like coolant is leaking from under the resovior somewhere. Please tell me this is an easy fix.
Old Aug 15, 2008 | 05:05 PM
Default RE: hello big puddle of coolant
Make sure that the car is cool. Make sure that the radiator is full.
Replacing the plastic tank or the hoses is very easy to do. First try to find the leak. Wipe off all coolant to help. Check the hose that goes from the radiator to the overflow tank for leaks. Also inspect the that drops from the overflow tank cap to inside of the tank.
Old Aug 15, 2008 | 11:37 PM
maro's Avatar
ORIGINAL: PAhonda
What do you mean by this quote
and
If I am under the hood, is the overflow tank adjcent to my battery, to the right the radiator. If so, that is where I am dripping. Under that tank/resevoir
Old Aug 16, 2008 | 01:29 AM
nafango2's Avatar
does it leak constantly or only when the engine is running?
i would double-check to make sure the leak is coming from the overflow bottle.
Old Aug 16, 2008 | 07:37 AM
Check the hose by squeezing it to see if the coolant gushs out of the hose...
Old Aug 16, 2008 | 10:06 AM
maro's Avatar
seems to be just when the car is running. I moved it from one parking spot to another, (while car was still kinda hot) and checked this morning, there seemed to be a tiny puddle underneath. So do I take out the battery first, and then pull the overflow tank? thanks
Old Aug 16, 2008 | 12:09 PM
ford's Avatar
you can remove the battery first if you want to..but you can also just pull the coolant tank it just slides in there...
rics06
Jun 12, 2013 07:11 AM
rics06
Jun 4, 2013 04:44 PM
oneloudskunk
Nov 29, 2010 07:06 PM
pr1286
Aug 22, 2010 01:22 PM
Apr 14, 2009 08:12 PM
